Hi all
I have been lurking for a while, but this is my first post here.
I recently became a 914 owner once again after trading an Alpha 1 outdrive lower unit for a non-running 1970 1.7 (damn boats, another addiction). It is in fair shape for a car that has spent it's life in the Northeast. It appears that it was "restored" in the late 80's or early 90's, and had been sitting in a garage for over 12 years. The car has the typical problems in the passanger side long & jack post area that will need to be cut out & replaced, a few patches needed in the floors, and rust bubbles under the bodywork in a few areas, but not in bad condition overall for a Northeast car (most of you West Coast guys would probably cut this one up for parts, but I feel that it can be saved).
I have been reading all of the restoration threads in order to get a game plan of where to start with the repairs. I have not cut into the car yet, but know that I will be cutting out and replacing alot of rusty parts.
In the repair of the longs, I was planning on cutting them open, removing all the rusted parts, stabilize the existing metal, patching back pieces where required and had considered using one of the clamshell kits. Have many of you guys used the RD clamshell kit? How does it compare to the Brad Meyer's long kit? Pros / cons with each one? I felt that it would be much easier using one of these than trying to fabricate the parts myself.
The hellhole has been already been patched together by the PO. This will most likely be cut out and replaced as well.
I have been out of the 914 scene for alot of years and will be looking to you all for advice, guidance and words of encouragement.
