Danny_Ocean
Oct 18 2007, 09:51 PM
I did a search and found numerous threads on replacing the trunk floor, but I want to remove my trunk floor permanently. I like the idea of having easy access to the motor/trans.
Any stiffening required? Cross braces? Car will eventually be a track car that is driven on the street occasionally.
Project 6
Oct 18 2007, 09:57 PM
Cut away, it's not structural. Might want to save the piece in case you want to put it back in.
McMark
Oct 18 2007, 10:09 PM
Like this...
After cutting it out, I stood on the tranny cross member (225 lbs) and bounced slightly while a friend watched for flex. He said he couldn't see any flex. So I think it's plenty strong.
Cap'n Krusty
Oct 19 2007, 12:40 AM
I disagree. While you may bounce merrily away on the crossmembers, you're not subjecting them to any angular stress, or any kind of dynamic stress. I also think the accessibility thing is BS. (sorry, that's how I see it) There's NOTHING you need to access that removal of the trunk floor would make easier.
The Cap'n
GeorgeRud
Oct 19 2007, 06:00 PM
It does make access to the transmission breather vent and upper starter bolt easier! Can't think of anytime that either were a major priority though.
scotty b
Oct 19 2007, 08:14 PM
DEFINITELY cross brace it. 225 lbs "bouncing" on the cross menmber is a far cry from the twisting it will do going down the road
Danny_Ocean
Oct 19 2007, 10:47 PM
QUOTE(Bass Fisher @ Oct 18 2007, 11:57 PM)
It's a little "swiss cheesy", so I thought I would take it out and see how I like it before going through the replacement process.
army dude
Oct 20 2007, 09:18 AM
Going through the same thing with my car right now. I will take out alot but the tranny brace as in the above pic but I will have support bars from shock tower to shock tower and from shock tower to tranny brace, both sides- left and right. But, all the bracing will be done low enough for me to still use the trunk to store my roof when I want to go topless. Everything will be done in appropriate sized tubing so if I ever need to go through tech for my runs at Road Atlanta I will pass without question. Better to do it once and do it right then to have to pay twice for crap work and stupid planning.
Ian
