My 901 is sometimes hard to get into 1st gear at rest. If I clutch it a few times, select a higher gear before 1st, or match revs with the gas and clutch, I can always get it to go in. It never grinds though(well except when matching revs with gas and clutch ). But sometimes, it just works like butter. I want it to always work like butter. And it does this with the motor stopped too, so I don't think its a clutch issue.
Everything else is new (bushings, mounts, Swepco etc.) Also, I have a rennshifter. The only questions for me are shifter adjustment (not sure its completely dialed) and the 901? Since it works like butter about 50% of the time, the 901 is my prime suspect. Would a worn 1st syncro cause this?
