QUOTE(Danny_Ocean @ Oct 20 2007, 04:33 PM)
OK. I understand now. I didn't realize powdercoat was similar to spray paint. I assumed that since there was an electrical charge involved, the spray would be attracted to the entire piece.
There IS an electrical charge involved and it WILL go all over the piece that is why you need to mask off when you do the seperate colors. Also, You will need to mask off for the black, coat it, bake it, let it cool, unmask it, reverse mask it, coat with the silver, bake the silver then let it cool and unmask. You cannot coat and bake both colors at once if you want sharp lines. The bicycle pictured above could be done at one time because of the fade. It didn't matter as much if one color invaded the others space. You will need to leave the masking on while the pieces back as the powder does have a tendency to float during the start baking process.
