OK, I started trying to correct the excessive negative camber on the rear of my teener to help tuck the new 10" wheels under the rear tubs. I was measuring negative camber in inches, not degrees or minutes. I started to order Engman's shim kit which would have given me about 7mm to play with. I thought it might be bright to try shimming it first with washers to make sure I had enough with 7mm. As it turns out, I have almost an inch of shims in there now, and I'm finally getting close to zero camber (still not there yet). So, what gives? Bent trailing arms? Deformed bushings? Both rears are about the same. Is it OK to run that much in shims to get the camber right? I know others have commented about doing it, but I want to make sure. Last, what would be the danger of using flat washers, and then shims on top to get to the correct camber setting? TIA
--jaybird
