QUOTE(9146986 @ Oct 21 2007, 07:07 PM)
I forgot to add that for all new systems, in addition to the method above, I say to mark the dipstick with 10.5 to 11 qts in the system and let that be the new max full mark.
I've been away on business for a few days. Thankyou for the information this has been very helpful. Interesting that you say that the tank is a similar volume to the std tank.
Couple more questions if I may. You mention about different lengths of dip stick. Can you measure one that is the right length for me ?
Where do you get the 'correct' one ?
I'm not sure I quite understand your comments about the filler neck. See the attached picture of my filler neck which connects to the tank by a short section of silicon hose using jubilee clips. This is the filler neck kit that was supplied with the tank by Patrick Motorsports. (After several emails to them over 6 months asking for advice they haven't replied to any apart from to say they are very busy and will reply in due course. They never did. Very disappointing).
Does this set up look right ?
Can you tell me the level the oil should be in the tank when it is hot ?
I could maybe then check it in service and make a dip stick to match.
Your help is much appreciated
Andrew
PS Sorry to disappoint at the Rugby. I think you will find we DID score a try but a blind Australian official disallowed it. I think the evidence shown since the match confirms that this was a duff decision. South Africa were probably a better side overall but Englands form in the tournament surprised everyone.
Didn't do too well in the F1 GP either. Lewis will be back though !
