flyloki
Oct 23 2007, 12:46 PM
About to send the car for paint and I want to weld the cowl seam and side marker light holes up. What's the best way to go about doing this?
Thanks
VaccaRabite
Oct 23 2007, 01:30 PM
Welding shut the cowl seam is a bad idea, at least that is what the brain trust seems to think. I left mine.
Welding up marker lights. I cheated when I did mine. I cut a patch slightly larger then the hole, cleaned off all the paint and tar behind the fender, and lap-welded the hole shut. A little bit of body filler, and you'd never know they were there.
I used this technique to close all the holes in the fender when I pulled out the AC.
You can carefully cut a patch and butt weld them in, and then grind the weld flat - but I don't weld that well, and wanted them done.
Zach
rmital
Oct 23 2007, 01:47 PM
QUOTE(Vacca Rabite @ Oct 23 2007, 03:30 PM)
..... I cut a patch slightly larger then the hole, cleaned off all the paint and tar behind the fender, and lap-welded the hole shut. A little bit of body filler, and you'd never know they were there.....
Zach
my attempt....
watsonrx13
Oct 23 2007, 03:39 PM
My preference was to cut out a circle and butt-weld into place.... This is before welding....
Click to view attachment-- Rob
tdgray
Oct 23 2007, 04:01 PM
Tooo much work....
Do as I and the first chimmers stated, unless you care what the inside of the fender looks like.
ppickerell
Oct 23 2007, 08:39 PM
QUOTE(tdgray @ Oct 23 2007, 03:01 PM)
Tooo much work....
Duh,
take it to McMark!
TINCAN914
Oct 23 2007, 09:37 PM
Leave the cowl alone, to much stress there in time the weld will break..
flyloki
Oct 24 2007, 03:33 PM
Thanks for the info everybody.
