minndodger
Oct 25 2007, 03:55 PM
Does anyone have any experience using a rebuilt fuel pump? What is the difference in life expectancy between that and a new one? The rebuilt ones are less than a third the cost is why I am asking.
Thanks for the advice.
Stephen
toon1
Oct 25 2007, 04:13 PM
Is it a 3 port pump? I have not heard good things about the rebuilt three ports.
You could replace a three port with a 2. 2 port pumps are cheaper.
minndodger
Oct 25 2007, 04:30 PM
Yes, it is a three port I believe. It is the original. I will check to see if I can locate a 2.2 port version. I do not know much about cars so I am kind of stumbling along this process. Thanks for the advice.
Stephen
toon1
Oct 25 2007, 05:39 PM
You can use an 2 port pump on a system that has a three port.
2 port pump are about $175. you should relocate the pump to the front trunk and replace the plastic fuel lines in the tunnel with metal lines.
Just about any EFI fuel pump will work.
Cap'n Krusty
QUOTE(minndodger @ Oct 25 2007, 03:30 PM)
Stephen
I have a new-in-the-box 3 port pump I would like to see go away. $420, delivered outside California. California buyers have to pay sales tax.
toon1
Oct 25 2007, 05:40 PM
minndodger
Oct 26 2007, 10:46 AM
What is the difference between a two port and three port system?
Cap'n Krusty
Oct 26 2007, 10:51 AM
The return line has no "Y" in the 2 line system. It goes directly from the FP regulator to the tank, skipping the pump. The Cap'n
minndodger
Oct 26 2007, 11:01 AM
QUOTE(Cap'n Krusty @ Oct 26 2007, 11:51 AM)
I would like to purchase the 3 port one from you. Please let me know how to proceed with the order.
Thanks,
sean_v8_914
Oct 26 2007, 12:13 PM
rebuilt is fine
