QUOTE(rfuerst911sc @ Oct 27 2007, 12:02 PM)
I have completed the installation of metal GT flares front and rear, these were butt welded. And I have installed the GT rear stiffening kit. All welds were ground smooth and seam sealer was applied where needed. I then applied a oil based rust preventative primer and then 2 brushed coats of a oil based high gloss enamel paint. I was going to apply one more coat via spray as a finish coat but before I do that I'm wondering if I should spray undercoating in the wheelwells? I live in Florida so not many rocks to kick up and no road salt. So should I just apply a finish coat of paint or undercoat? If I undercoat is there any advantage to applying paint over the undercoat? I kinda like the look of the painted inner fenders.
Porsche, Mercedes, BMW factory recommended replacement material
Comes in bulk and spray cans. Black, gray and tan.
Goes on thin, can be left as is or painted over. It's the stuff!
You still need to prime and apply a base to the metal under the wells.
The product is urethane based. Not greasy like body shutz.
