So I am dealing with the wiring, and I need some help. I tried the wiring diagrams in the Haynes manual, but they don't seem to match up. So I took notes and here's where I need some help:
_____________________________________________________________________
The Harness @ Relay board has 2 sections. One that goes under the car to the starter and one that stays on top.
Under: Backup Lights (2 x bullet connectors), and 1 X spade to starter (is the starter connection correct?)
Above: 4 Wires that I don't know where they go.
White
Green/Red
Brown
Black
__________________________________________________________________________
@ the Battery
Big thick black from + terminal to starter (correct?)
Ground to - terminal
3 x Red wires (sort of bundled) to + terminal (correct?)
From Alternator
Single Red to starter? Same post as battery connection?
Dizzy (with pertronix) Red & Black (I assume to coil. Want to confirm which color to +/-. Don't want to fry the dizzy.
Relay board
Added ground jumper per Sir Andy's technote for carb fuel pumps.
Also, I need to move the dizzy since it looks like it will interfere with carb linkage in the stock location. Suggestions.
Thanks in advance for the help!
