QUOTE(Hammy @ Oct 27 2007, 08:01 PM)
Ok - I have most of my vacuum lines hooked up (1.7 Djet) but there are still some connections I'm unsure about and if they're needed.
-Two vacuum connections from each head into the flashback valve, and then into the air filter. Needed? I have this hooked up but it didn't seem to make a difference whether connected or not.
Not needed to run, but needed to keep oil out of the engine bay. (Incidentally, it has been illegal to vent the crankcase and heads to the atmosphere since 1965, according to the Cap'n.)
-Back side of the vacuum canister on the distributor. My dizzy only has the outside vacuum nipple/connection.
Then either you have the wrong distributor, or something is wrong with your vacuum gizmo ("dashpot"). There should be both an advance (the one you have) and a retard (pointing back toward the distributor body) fitting. If there are two fittings on the throttle body, both of those should be hooked up. The advance fitting should be hooked up to the fitting on the rear side of the throttle body, the retard fitting to the one on the front of the throttle body. Cap off any throttle body fittings that you cannot hook up correctly; leave the distributor fittings unplugged if you cannot hook them up correctly.
-I have totally deleted the deceleration valve circuit, and capped off the decel valve vacuum port on the intake air distributor and also plugged the small connection from the AAR to the decel valve. Is this ok to do?
It's better to have the decel valve, but the engine will run without it. Plug any fittings that used to go to the DV. Though the "small connection from the AAR to the DV" confuses me. Perhaps it's a 1.7 thing that I haven't looked at...
-Haynes manual shows a hose from the air filter to the same spot where the MPS hose plugs in on the intake air distributor. What's this ? I don't seem to have the connections for this.
The Haynes illustration is from a VW Type IV, not a 914. Ignore that connection.
-Charcoal canister and fan housing connections. My fan housing connection is completely unhooked and unplugged. Haynes shows a hose from the fan housing to the air filter. Is this needed?
Fan housing gets connected to the charcoal cannister. The cannister gets hooked up to the air cleaner housing. Not needed for the car to run, but needed to keep gas fumes from getting out into the air. An emissions requrement, and completely harmless to the engine's performance.
--DD
