drue
Oct 29 2007, 02:51 PM
What's the red fuse (25 amp?) on the relay board and does it matter that I don't have one? I'm assuming it's for an option my car doesn't have, but I'm just guessing.
Click to view attachmentClick to view attachment
Rand
Oct 29 2007, 03:10 PM
I thought the 25A relay board fuse was:
Heater Blower, Fuel Pump, Rear Window Defrost
yenningComity
Oct 29 2007, 03:32 PM
Not to hijack, but the 4 cylindrical objects *the name escapes me atm*. What are they for? I ask because my car has one missing.
drue
Oct 29 2007, 03:50 PM
yenningComity,
Those round things are relays but I can't tell you which is which.
anderssj
Oct 29 2007, 04:01 PM
If I remember, the fuse closest to the firewall is not usually used (one end connects to “8” on 14-pin connector [black from ignition switch “15” + in run], the other to "9" on the 12-pin connector [not used]).
Hope this helps . . .
ejm
Oct 29 2007, 04:28 PM
QUOTE(anderssj @ Oct 29 2007, 06:01 PM)
I think it may have been for the electric chokes on carburated engines
BTW:
to the new guys
Rand
Oct 29 2007, 04:34 PM
Hold on.... Not related to carbs.
Dang, I'll have to dig this up when I get home.
You know, this is in the Haynes..... If you don't have a Haynes manual, that is a necessity.
Rand
Oct 29 2007, 05:06 PM
From front to back, these are the four relays:
Rear window defogger (optional) <-- so correct in that often not used (closest to firewall)
Power supply (not sure how to expound on this without the manual)
Fuel pump
Heater blower
jk76.914
Oct 29 2007, 07:10 PM
"Power supply" is the power to the FI electronic control unit. In addition to flowing power to the ECU, it turns on the fuel pump relay.
Rand
Oct 29 2007, 07:11 PM
Thanks Jim. What is the third one then? ("Fuel pump")
jk76.914
Oct 29 2007, 07:19 PM
QUOTE(Rand @ Oct 29 2007, 09:11 PM)
You had it right- 1. defogger, 2. fuel pump, 3. "power supply", 4. heater blower.
