Does anybody know what that port is on the inside of the rear brake calipers? It's right up against the trailing arm (you have to remove the caliper to even see it) and right above the hand brake lever. My left rear caliper is leaking, and I think it's from that port. If I blow air into the right side caliper with my finger over that port, I feel nothing, but if I do the same on the left, I get air out of the port. Does anybody know what this might be and how I may fix it. Brakes are not my specialty. Thanks
Mark D.
