JOE M
Nov 5 2007, 12:23 PM
I have a 72` tail shifter. Just curious where the drain and fill are on the tranny. Also should I use gear oil and how much?
Thanks
davep
Nov 5 2007, 12:29 PM
Drain & fill are the 17mm allen key plugs on the right side. Be sure the top (fill) plug comes out before you remove the drain plug. Use the proper gear oil, and fill until the oil is to the level of the top plug.
