kckoch
Nov 6 2007, 09:15 PM
E-bay has a listing for S gears, so I thought I would go to my stash and see what I have that looks like them.
Well from the pictures, mine look exactly like the ones in the pictures. In fact, I think I have two sets.
How do I tell what I have. Previous owner had all kinds of stashed goodies, mostof which I know. But when it comes to transmissions, I'm clueless.
I plan on a 915 trans anyway, so I'm just trying to figure out if someone can use them.
davep
Nov 6 2007, 09:36 PM
Count the teeth on each gear of the pair. That will allow you to determine the code # of the pair. From there look up what the gears were used for.
Dr Evil
Nov 6 2007, 09:37 PM
Special gears are useful to many. Unless you count the teeth you can not tell what you have. Here is a chart to give you count ideas.
Cap'n Krusty
Nov 6 2007, 10:22 PM
If they're "S" gears, they're from a 911 (or 912 box). If that's the case, they're ALL stamped with letter codes. Those codes are in the specs books for 911/912s.
The Cap'n
Aaron Cox
Nov 6 2007, 11:10 PM
gotta count teeth.... (like on girls from bakersfield)
Dr Evil
Nov 6 2007, 11:17 PM
QUOTE(Aaron Cox @ Nov 7 2007, 12:10 AM)
So.Cal.914
Nov 6 2007, 11:31 PM
QUOTE(Dr Evil @ Nov 6 2007, 09:17 PM)
lotus_65
Nov 7 2007, 07:06 AM
i was looking at those too, i have a buddy who said i should get some taller gears for my raby 2056.
you guys have an opinion on which ones i need?
thanks,
paul
jd74914
Nov 7 2007, 10:26 AM
A bunch of people like using MSX on hopped up cars because that combination provides better acceleration. Do you want to be fast or quick?
lotus_65
Nov 7 2007, 11:14 AM
oh yea, i guess that matters! i'm strictly noob on this, so~
he thought i should be geared taller, but that'll just get me mashing it more, right? it seems like the engine would be happier with longer runs, but i may not want that in 2nd and 3rd because i want as much torque as i can get in traffic.
basically, fast... highway star style.
thanks!
kckoch
Nov 15 2007, 07:28 PM
So humor me here (I already said I don't know transmissions). Teeth count is 25 on small one and 34 on big one. So from the chart what do I have?
911quest
Nov 15 2007, 07:42 PM
Looks like you have a mismatched set one froma 1st gear and the other from a 4th or 5th gear.
Dr Evil
Nov 15 2007, 07:55 PM
QUOTE(kckoch @ Nov 15 2007, 08:28 PM)
Well, are you sure that those 2 go together? Do they fit together? That would at least let you know they were from complementary shafts. If you are not sure they go together then you may have part of 2 different gears. OR, they may be from a 911 tranny, but I do not know the 911 ratios off hand.
davep
Nov 15 2007, 09:45 PM
http://members.rennlist.com/chuxter/901&915ratios.htmfrom the chart you have nothing but two unmatched gears.
