Hi,
Does any place sell kits of these to replace rusted and damaged ones? Haven't looked at the fronts in a while, but my rears do need new ones the next pad replacement. ( this spring at the latest)
Thanks,
Tom
Dave_Darling
Nov 7 2007, 02:52 AM
Front brakes:
411 615 269 EXPANDING SPRING >>47229 19032 -72
411 615 269 A EXPANDING SPRING 47229 19033>> 72-
411 615 261 RETAINING PIN >>47229 19032 -72
411 615 261 A RETAINING PIN 47229 19033>> 72-
Rear brakes:
311 615 269 EXPANDING SPRING
901 351 913 14 RETAINING PIN
914 352 925 00 RETAINING PIN
[I'm not sure which is the larger pin and which is the smaller pin]
The clips are not mentioned separately. "Hitch clips" are available in most auto parts stores, though.
I once got a part listed as a "repair kit" for the rear caliper; it had the clips as well as the plugs for the adjusters. It might have had something else, but my memory of it is now foggy. The following might be that kit:
914 352 900 00 REPAIR KIT PLUG
You can try entering these part numbers into the "search" field over on Pelican. (Presumably other on-line catalogs have a similar feature.) Some or most of them are probably NLA at this point.
--DD
Thanks Dave,
I'll check these out.
Tom
