swood
Dec 30 2003, 08:41 PM
I think they came from you to another clubber. Konis for the rear and 140# springs.
Can you tell if they're adjustable or not or if I can just yank the old ones (same color, but hecho in mexico) out and put these in? Not sure if I need anything else.
Thanks.
Steve
swood
Dec 30 2003, 08:42 PM
top
Aaron Cox
Dec 30 2003, 08:46 PM
drifter jay has some orange/red boge's on his car with a non adjustable perch that looks just like that....
Dec 30 2003, 09:38 PM
QUOTE(swood @ Dec 30 2003, 06:41 PM)
ICan you tell if they're adjustable or not
i don't see any adjustements ...
Andy
Eric_Shea
Dec 30 2003, 09:45 PM
Look like older Koni's. Boge's (usually) have a yellow zinc cap on the top. If they're either they'll say so right on the side...
Eric_Shea
Dec 30 2003, 09:47 PM
Britney avatar... "fun facts" her old guitar player is a teener owner. He's now playing with Justin.
Eric_Shea
Dec 30 2003, 09:49 PM
Dampening is adjustable. Push down on the rod all the way and turn until you feel a click... twist away.
Korijo
The older Reds adjust by pushing the shaft all the way in, and twist the housing left or right to stiffen or soften.
I dunno which way is which
Eric_Shea
Dec 30 2003, 09:56 PM
If they're Koni's there will be an arrow stamped on the side that says "Heavier". I believe it's counter clockwise to soften and clockwise to tighten.
swood
Dec 30 2003, 10:02 PM
QUOTE(Eric_Shea @ Dec 30 2003, 07:56 PM)
They're Konis. Heavy D is stamped on it. I do see an arrow pointing to the right and below it is stamped Heavier.
Starting to make sense. Since I know zip, do you set them before installation or after? I suppose you'd crank them both evenly to start and then work your way hard or soft.
Korijo
Dec 30 2003, 10:08 PM
Before.
Yellow sports (and new Reds, too) adjust after install.
Eric_Shea
Before...
Correct Sir! Check www.konina.com for directions.
swood
Dec 31 2003, 03:27 PM
Thanks. I'll look into it.
Brad, any other info?
Brad Roberts
Dec 31 2003, 03:31 PM
Not really. Everybody above this post kicked ass. I throw them away..LOL The springs dont ring a bell with me.
B
914werke
Jan 1 2004, 04:57 PM
Throw them away
I think I have a set on the 74 with a AM adj. perch spring setup.
Brad Roberts
Jan 1 2004, 05:07 PM
You have seen the tubs we cut up... If I kept everything I accumulated over the years... I wouldnt be married and I would still live in Texas.
B
swood
Jan 1 2004, 10:43 PM
Why would I chuck them? The ones on the car now are shot, and made in mexico for that matter.
Brad Roberts
Jan 1 2004, 10:53 PM
I didnt mean YOU throw them away. I meant I throw away the old/bad ones.
Sorry for he confusicism...LOL
B
