QUOTE(Cap'n Krusty @ Nov 8 2007, 07:08 PM)
...................... But it won't tell you how it'll actually shift when the car's in motion. The Cap'n
The Cap'n is absolutly correct, it will not tell you if the synchro's are bad, etc.
But it will tell you if there is a scattered gear or broken shaft. But with another
person you could switch the trans in an hour or so, then test.
