I found another cleaner that worked fine. I put a second coat on and it mde little difference. I guess I would say in a nutshell that it is fairly sucessful. only time will tell how it holds up and how long before it crakcs if it does. I left it outside overnite to see how it would react when I brought into a warm house. It was about 23f in Hudson N.h last night so it is a good test. The finish seems pretty robust but it still has a similar feeling to an original dash. If I push on the surface it is not hard and brittle and does not feel like it will crack. I think that if you have a dash that is in bad shape and you dont mind a do it yourself project it is probably worth the $10 and a few hours of your time. I received several p.m`s on the steps I took to do this so here they are.
1)Clean the entire dash and try to get rid of all grime. Sand it if you need to with a fine grit paper around 100-150.
2)Next I aplied the filler with my fingertip so I could work it deep into the cracks.
3)After a few hours I sanded the filler flush to the dash.
4) Apply a primer that is good for either plastic or vinyl.
5)lightly sand the primer again using 100-150 grit.
6) Apply the vinyl polymer coating and let it dry for several hours. On my first attempt I tried to handle it right away and the finish was easily disturbed. It seems best to let it dry overnight.
7) If the finish is not what you want lightly sand any areas that are unacceptable and apply a second coat.
Remeber I am only 3 days into my project so I have no idea how long this will hold up. I think that if you have a dash that you have already considered replacing it may be worth a shot but if you have no intentions of replacing it and it does not work for you than youre stuck.
Here is a close up this morning.
