Hi guys. I'm almost finished reassembling my car, but I've run into a snag.
Before it was taken apart, all of the lights and blinkers worked fine. Now, I think the blinker relay is broken (it was acting erratically before) and so the blinkers won't work. But, the major problem is the the brake lights and reverse lights won't work and the alternator light is on. The alternator is charging right (at least, there is about 14V when running on the battery and running it doesn't drain the battery).
When I push down on the brake pedal or put the car into reverse, the tach goes to 0, the alternator light really brightens and the radio turns down. Also, when the car is running without the brake petal pushed down, the tack is not showing the correct rpm; it is about 1500 rpm too low When you turn on the headlights (they work) the tack starts reading right.
I'm assuming there is some kind of short in the whole circuit, does anyone have an guesses on where it is before I test all of the light wires?
To summarize:
No brake/reverse lights work now (they did all before)
No blinkers work (but I think the relay is just broken)
When running in neutral the tack shows an rpm 1500 lower than correct and the alternator light is on (but it is working right)
When on the brakes or in reverse the tach stops working and the alternator light gets really bright.
Thanks for any help in advance,
Jim
