I thought I would start a new thread to see if I can get some help.
I just replaced my fuel pump on my '73 2.0. The fuel pump is in the original location near the engine. I posted previously about this and the Capn gave some pointers, but the car is still not starting. It tries to start and does run for a second or two and then dies. The Cap'n says it is starting on the CSV. What I don't understand about the CSV is: Where does it get the gas from? I would think it would get gas from the fuel pump.
Here is what I have done so far.
I have checked the electrical connectors to make sure that + is to positive and - is to ground. As long as the stamping on the housing is correct, I have it connected correctly. I can hear the pump turn on when I turn on the switch.
I have the fuel line with the "Y" connector on the lowest pump orifice - this is the one nearest the electrical connector. The Cap'n also said the pressure relief valve is there. The single fuel line that goes up into the engine compartment is connected to the middle orifice. The supply (coming from the fuel filter) is connected to the top orifice.
I have checked for gas flow through the filter and it is flowing freely. I have disconnected the fuel line (middle one on the fuel pump), in the engine compartment and when I turn on the switch and hear the fuel pump come on, no gas comes out. I am assuming that it should.
So, either I have the fuel hoses mixed up, or the pump is not working. I just got this one from HPH so I would hope it would be good.
So, what next?
Warrenoliver
