QUOTE(SLITS @ Nov 13 2007, 11:15 AM)
I don't screw around on tech questions ... I'm serious
You want to know how they work and the internals ... go to the library and read.
I've had them stuck open and stuck closed. I've had them fouled (clogged). I've had them where the solenoid is bad and they won't open.
The CSV has been known to be a culprit before. I just fixed an engine where the #1 plug was WHITE ... what would be your guess?
When you're guessing from miles away and don't have your hands on the vehicle, there are a multitude of things that can contribute to a situation. You need to check ALL of them.
I know what the internals of a inj. looks like
If you know what the internals of an inj. is, then you would know that excessive fuel pressure would case it to SHUT not stick open.
Can you give an example of a problem you have run accross where excessive fuel pressure caused an inj. to stick OPEN?
All the problems you described above are not the result of too much FP.
They are the result of a failing injector, that's different.
you could take and 914 inj. and apply 60psi to it and it would work fine, they only start to have opening probs. at around 70psi.
Most of the flow rates for a 1.7 or 2.0 inj's. are taken at 43.5 psi., which is what modern fuel system pressures run.
