derekdenman
Nov 12 2007, 06:09 PM
I am hearing a pop sporadically while driving at a constant RPM. Whenever it pops you can feel the engine miss as well. The engine is a very fresh 2056 with dual Dellorto 40’s, mild carb web cam, and a stock 050 distributer. Also it runs strong from idle to about mid throttle but after mid throttle it has no power and goes from a smooth sound to a very low throaty sound. It seems like it is rich due to the lack of power after half throttle but it the pop seems like a lean miss. Any suggestions? Maybe multiple problems?
degreeoff
Nov 12 2007, 06:12 PM
Hmm sounds almost like a ignition issue....
cobra94563
Nov 12 2007, 06:20 PM
I'm experiencing something similar (on a different engine).
I have an O2 sensor on the exhaust and my mixture is fine thru the range, so I'm thinking something in the ignition.
derekdenman
Nov 12 2007, 06:28 PM
I am running a Crane XR3000 ignition with the LS91 coil. The wires plugs, boots, and cap are all new. One the vacuum advance there are two nipples. One nipple is pulling a vacuum from the manifold. The other (closest to distributer) is not connected to anything.
Allan
Nov 12 2007, 06:50 PM
Clogged idle jets.
IronHillRestorations
Nov 12 2007, 07:00 PM
Ed Mayo once told me that half of carburator problems are ignition.
Check to make sure your distributor is getting full advance, and also check your timing at full advance.
If that checks out OK, then I'd suspect you might need to go up a size on the main jet. I don't know how much trouble it is to change jets on Dels.
thomasotten
Nov 12 2007, 07:16 PM
Sounds a lot like the same problem I ham having. I'm running Dells too. What are your jet sizes?
So.Cal.914
Nov 12 2007, 07:59 PM
Well theres your problem, I run Webers.
degreeoff
Nov 12 2007, 09:12 PM
QUOTE(derekdenman @ Nov 12 2007, 04:28 PM)
Ummm dumb question but the other nipple is plugged yes?
I mean if its not then you'd be getting no vaccum I PrEsUmE?
SEE next post....
Ok so I am an idiot......thats what a 009 and soon to be a crankfire system will do to a guy
Twystd1
Nov 12 2007, 09:28 PM
If ya plug the other nipple. The advance plate won't move... ya leave it open
Clayton
Joe Ricard
Nov 12 2007, 09:31 PM
These threads are sooooo funny.
What RPM cruising up to 3500 RPM Throttle slightly open. you are on the idle jets feeding though the progression ports.
As the throttle opens up and RPM increases the mains start flowing so if you put your foot down and it runs good then it isn't the mains.
I bet one partially clogged idle jet. which causes you to run lean.
thomasotten
Nov 13 2007, 06:16 AM
I have heard bad things about that distributer, 050.
Thack
Nov 13 2007, 09:47 AM
Sounds like it's lean before you get into the mains. That low/mid throttle transition is tricky with carbs. Does it get better once warmed up?
Borderline
Nov 13 2007, 10:49 AM
Look for a vacuum leak. spray some carb cleaner around the intake manifold and head while the engine is idling & listen for a change in idle speed. I was so sure my new thick universal gaskets couldn't be leaking...........wrong. Also, if the carbs are older, they may be leaking around the throttle shaft.
