Full Version: Harebrained idea about chassis stiffening
jamara
Well, I am not engineer, but I’ve got a harebrained idea for reinforcing the longs of the 914. I want to run it by you more experienced engineering types out there.
Theory:
1. Engman’s kit strategically places steel on the longs and lower firewall. Why? Because two pieces of sheet steel welded face to face are stronger than one by itself.
2. However, two pieces of sheet steel, separated and firmly affixed to a lighter weight material (fiber, honeycomb, thermopolymer, etc), is exponentially stronger than two pieces of steel welded together. Here is a site with more than you ever wanted to know about composite sandwich materials. The section at the bottom under "Core Materials for Sandwich Structures" is what you want. Pics at the bottom are a good illustration of the principle.
http://www.mdacomposites.org/mda/psgbridge..._materials.html
3. A similar technology is being used on modern cars during their production. They put polyurethane pour foam into the A and B pillars, as well as the rockers of new cars. It deadens sound and really makes the chassis rigid. Here is a link to a “tuner” car that this was done to. Look under “Foam filling the chassis”
http://www.sportcompactcarweb.com/projectc...rt_5/index.html
4. In terms of applying this to the 914 longs (putting pour foam in them), RUST is the deal killer. The longs on my car are “rust free” but still have some surface rust inside. With solid material in them to trap moisture, this could become a major problem. Also, the longs are fairly voluminous and so cost for foam and the resulting weight is another issue.
So, here is my proposed solution.
IPB Image
This would involve welding ½” x ½” ½” tube steel to the inner long in a lattice configuration. Then as with the engman kit, preformed sheet steel (18g) would be rosette welded to the ½” tube steel pieces, to the floor pan, and to the upper door sill seam where the inner and outer long meet. This would leave a ½” gap between the inner long and the “skin” The lower firewall would simply have steel added like the Engman kit, or perhaps this sandwich method could be used.
Now the good part….
8lb per cubic foot polyurethane foam could be mixed and poured into the ½” gap on the inner long. There would need to be evacuation points for the urethane foam so that when it expands it doesn't blow the welds.
Advantages:
1. Only 2.7 lbs extra weight in polyurethane given about 1/3rd cubic foot for both sides
2. Since we are dealing with the face of the inner long, it could be cleaned, phosphatized, Por-15’ed, gold plated, whatever, before everything is buttoned up. No rust issues.
3. Extreme rigidity since sandwich materials like this apparently behave like monolithic (solid) structures . In other words, it would be like having a huge 1/4" thick Engman kit with a fraction of the weight.
4. Only ½” invading the cabin area, as opposed to a roll cage.
Problems:
Relocation of the E-brake handle to the center console and possibly the back pad not fitting quite right. Also, the speaker grills in the front would need modifying. The ½” is not much but could cause problems here. Plus, my proposed design is to attach the top of the “skin” to the ½” lip at the top of the door sill where the inner and outer long are spot welded together. This is the area where the lower, inner door seal slips on and is held in place. Therefore, the trim piece that goes here would not fit without modification and the seal would need to be modified as well. Last thing, the seat belt bolt holes might need to be moved to the floor pan.
Anyway, this is just an idea, so don’t anyone start foaming at the mouth over it. (I will discretely NOT add a link to the 914world forum topic on the subject of pour foam in the longs, where someone started typing obscenities and colorful metaphors over the matter.) What do you think…?
jd74914
Welding in those square pipes would take a lot of effort. I think that if you want to foam the chassis it would take less time to cut open the longs and neutralize the rust (so that you can spray foam in them) than it would to weld tons of little tubes on.
As far as rigidity goes, that would be much better than a narrow layer. A thin layer like you suggest seems to me like it would have too little sheer strength in the given combination. I do not believe that suck a narrow laminate would give the torsional strength you are seeking. A roll cage decreases chassis twisting, such a narrow sandwich seems unlikely to help with twisting (at least anywhere near the degree of a cage).
You could do a FEA analysis on it to find out, for sure but in my opinion you are better off fixing inner long rust and spraying it in there.
jamara
QUOTE(jd74914 @ Nov 14 2007, 02:11 PM) *
I should've mentioned my car is a shell right now. In that sense, the inner and outer longs are equivalently accessible. Actually, the inners are more so cause the outers are partly covered by the door sill.
You might be right about it taking some time to get the squares done, but when the outer longs are cut open and rewelded, the welds should probably be ground down. The 1/2" tubes would not require that. It would go fast, I think. Plus, on a chop saw they could be cut in 5 minutes. The skin is where the work would come in, but not more than the Engman kit. Fabing the skins would be the chore. You might be right about the overall time it would take, though. The foam in the longs might be the fastest way, after fixing any potential rust.
I agree that the urethane would not help torsional (twisting?) load on its own. That is what the square tube lattice is for. This would create tremendous shearing strength for the two skins, which is what ultimately causes torsion (right?, wrong? not sure?) But 8lb pour foam is pretty dense stuff and would only add to the shearing strength. Granted, all the components of their own are not very strong. It is their functioning together that really makes them strong, but I suspect you know that.
I thought about putting the foam in the longs for a while. But, aside from the rust, I don't know if I want that much material in there. It would take about 16-20 lbs of it at 8lb density. Maybe I should go with 4lbs. 2lbs is simply not enough gain for the trouble. I guess it wouldn't be that much weight compared to a cage, or even the Engman kit. Something to think about, anyway.
Thanks for the reply!
davep
8lb density pour foam? Are we talking polyurethane here?
We use 2lb density foam in our coolers for insulation and strength. It is injected under high pressure as a liquid mixture that reacts and rises to fill the void in the walls of the box. However the foaming fixtures are 1/4" plate steel with lots of reinforcing. I can only imagine what pressure would be created by 8lb density foam.
jamara
QUOTE(davep @ Nov 14 2007, 04:38 PM) *
Exactly, polyurethane, two-part foam. Mix it up and pour it in. During application, there would definitely need to be evacuation points for the foam as it expanded so it would not blow the welds. Also, measuring everything out with semi-precision would be good. In other words, X volume of premixed material makes X volume of expanded material, so don't over fill! This would prevent me from turning my teener into a big rolling marshmallow. biggrin.gif
Also a two stage application might be good. First, do the vertical wall. Let it expand and ooze out of some predrilled holes toward the top of the long. Then, do the horizontal section, also allowing for expansion via other pre-drilled holes. I didn't think it was necessary that it be applied under pressure since it expands to fill the voids of its own accord. Yes, no?
All of this is, of course, only theory. So it could go down very differently if I actually tried it. I could end up making an expensive sculpture out of a 914.
Katmanken
Ever notice that the areas in a teener and beetle that the germans used foam in rust from the inside out?
The other is merely increasing the height and width of the beam to increase the moment of inertia to stiffen it. Thats why a 6 inch diameter pipe is stiffer than a 1 inch diameter pipe.
Ken
drive-ability
jamara,
I like the fact your thinking outside the box so to speak. I too would love to able to fill the longs with a polyurethane, hey maybe 95 shore Ha but rust is a problem anyway we tackle this issue. As soon as one part is hardened another starts to crack etc..
Keep working on it !!!
byndbad914
I would hack the inside of the longs and the floor completely out (but leave behind the center tunnel if you want stock shift mounting, etc.). Then box the car with 1.75 diam 090 chromoly or 2x4 120-wall DOM welded to the inside of the outer long steel. Run a couple 1" tubes across for seat supports, and then use 1/8" off-the-shelf laminate for the floor. Would be easier and work better.
That foam core makes a great filler but I question its bond strength in shear. Additionally, the strong laminate stuff has aluminum core with varying cell size and wall thickness, not foam. I know there is foam core stuff being used in home construction and so forth, but the light and really strong stuff is not going to have a foam core.
jd74914
QUOTE(kwales @ Nov 14 2007, 08:43 PM) *
Ken
The foam does work as a stiffener. That's proven; we've actually used it in statics problems. laugh.gif The problem with it is rust.
Borderline
My idea would be to work on the outside similar to the engman kit: Sandblast the long to get a good clean somewhat rough surface and then laminate layers of carbon fiber using epoxy resin for good bonding properties. carbon is stiffer and lighter than steel and would be relatively easy. just a thought, FWIW
Aaron Cox
QUOTE(jd74914 @ Nov 14 2007, 09:18 PM) *
Ken
hah! i am missing out...
andys
QUOTE(byndbad914 @ Nov 14 2007, 08:45 PM) *
That would sure stiffen it up!!!!
I saw a similar idea implemented on a V8 car I saw a few years ago. They used channel iron on each side outside of the longs with round tubing bridging between them similar to what you describe. The channel hung about 1" below the long with the tubing below the pan. The execution was a bit rough, but the owner claimed it made a huge difference. Not how I would have done it, but that's the idea.
Andys
byndbad914
QUOTE(jd74914 @ Nov 14 2007, 10:18 PM) *
Be careful as to what you mean by "stiffer". that is a bogus term overused in engineering. What was stiffer?
If you have two facesheets and you throw some foam between them, but the foam doesn't BOND to the facesheets, then it may be good for filling a void and reduce localized creasing and buckling and supply stiffness in compression, but put the two facesheets in shear with each other and you slide them apart. So how well the foam sticks to the metal is the important question.
If you did a "statics" problem with a composite stiffness calculation, be careful what your assumptions are. Most basic problems assume stiffness is perfectly transferred thru all the materials and therefore assumes the components are perfectly bonded. However, there is a true shear strength to the bond joint and tho' mathematically the joint is "stiff" the bond sheared a long time before and the joint in reality is junk.
FWIW
davep
Free rise density of the foam is less than 1 lb per cubic foot. To get the 8lb density you are talking about means containing it in a very strong fixture until it cures. Even then, if the foam is not well mixed (impingement under about 1000 psi, think two opposed nozzles in a very wide \/ configuration), then you can have unreacted material that may react even years later and grow again. We had problems like that with coolers up to five years old that just burst the casings with 1/2" wide cracks. Using foam for structural purposes is a tricky prospect.
jd74914
QUOTE(byndbad914 @ Nov 15 2007, 12:47 PM) *
FWIW
I should have been clearer. The point of his example revolved around helping reduce buckling in columns.
And Aaron, you definitely missed out laugh.gif . . . I think adding some "homemade" problems in was his way of breaking up the monotony... fun (of course this is coming from a guy who has custom caution tape that says "DRAW FREE BODY DIAGRAMS" and a parrot which repeats the same.) laugh.gif
jamara
QUOTE(davep @ Nov 15 2007, 09:58 AM) *
This is very good info to know. I have heard this sort of thing must be mixed well, but I didn't know it required this degree of processing. The products I have found do not seem to require it. Also, they are marketed as 8lb foam and are designed to be mixed with a power drill and attachment, then poured in place. The density is determined by their chemical composition, not the pressure under which they cure. So, we may be talking about two different polyurethane foams. I wonder if I'm thinking of the right stuff. Something like this, in a small quantity, is what I had in mind.
http://www.polyfoam.cc/products/foam/mold.html
The site says it is all hand mixable and the higher densities are for structural applications using sandwich composites.
davep
You guys might be correct that some of the foams may get that density in free rise. Be sure that it is a free rise density though, and then be very sure you get the quantity bang-on for the volume you are filling. You want to be sure that it fills the entire cavity and does not trap bubbles of air. Those bubbles would reduce the filled volume. Excess volume of foam will always create high pressures. We can often find voids in complicated parts where the foam was too stiff to flow in narrow areas. It gets tricky.
jamara
QUOTE(byndbad914 @ Nov 15 2007, 09:47 AM) *
You are absolutely right about the adhesion of the materials being critical. This is my understanding as well. However, everything I am reading about this polyurethane foam says if it gets on something and you don't want it there, you are SOL. It doesn't come off anything but smooth plastics, apparently. This is why it works as a sandwich material in structural applications!
If the surfaces are properly abraded, then I would think this stuff would stick like superglue. Also, I added the 1/2" square tubing in V formation to address the shearing issue, as well as making the wall thickness consistent. There would be little chance for shearing with the two facesheets joined in this way... the 1/2" tubes welded to the longs and then rosette welded to the skins would be like the Engman kit, only much, much stronger. The foam, in that sense, may be an unnecessary after thought except that it does fill the voids between the tubing and provides additional shearing and buckling strength. I don't know, but my intuition and research says it would act like a piece of 1/4" angle iron, only 1/2" thick and much, much lighter. Is this not what the Engman kit does, only 18 gauge (1/20")?
All that said, I am leaning more toward the tubing idea as you have suggested, but I think I might not completely remove the inner long, just supplement it somehow by welding the tube steel inside the long as you suggested and then putting the inner long back on. Who knows...
I am going to do something though! I want to create an elegant yet highly effective solution while incorporating some modern design techniques with the caveat that it be cost effective (I'm no trust fund hippie) and do-able in my garage.
FWIW
Very true. But... The polyurethane foam in cavity technique has been proven in real situations. Not to say it is as strong as theoretically possible or that it will work indefinitely for all load types, but it has been made to work for certain apps. davep has just said his company uses it for insulation and strength. Some of the tuner guys are supposedly getting success from it (never know about some of those ego maniacs, though). It is used in modern production cars.
Ultimately, it may not be worth it but it could be interesting to at least do some small model testing. Hmmm... card board and Home Depot expanding foam, anyone...??? Put a twisting load on it, before and after, see what happens... ??? hmmm... Materials are too different, I'm afraid. Maybe I'll try it anyway, for kicks.
Katmanken
I've built aluminum and foam core structures for military applications. The foam was used to stiffen a thin aluminum floor so yer foot wouldn't punch a dent in it and to stiffen the outer skin for the same dent reasons. Aluminum tubing stringers are used for the strength and load carrying capabilities as the skin wouldn't handle the load. Lightweight structure, but my analysis showed the foam wasn't capable of proper load carying abilities- even with aircraft structual epoxy.
Kinda like wood 2x4's in your house carry the real loads, the drywall and foam sheet insulation don't.
As you may surmise, I fricking hate ruining a good german car with spray foam. VW sprayed the crap into my Superbeetle and after 20 years, the rust came through the steel from the inside out in areas that never see moisture. I had to cut welded steel to get in there and the rust was only under the foam and not in metal right next to it which leads me to believe the foam is corrosive or becomes so over time.
And why the heck you would look at a torsion load is beyond me. Rockers get bending and compressive loads, and not a lot of torsion.
Ken
Brando
I second the carbon fiber idea.
The only way I could see foam injection working properly, as intended, without causing damage to the material of the car, is in a carbon fiber chassis.
Can someone crank out a teener body, primed in white, made of carbon fiber real quick? Thanks.
byndbad914
jamara - I am familiar with using poly in cavities. The main benefit, as I suspected in regards to the statics problem, is in compression. Put it in a hollow beam and you have a lightweight way to increase buckling capability. Similar foam concept is used in houses (SIPs) and it is used mostly for the insulative properties, as you mention others have used it for in cars. Modern production cars use it internal to hollow sections to increase buckling and bending stiffness.
Aircraft wings use poly core, but they form from solid (don't fill with liquid per se tho' I believe some small craft guys do that tho' I wouldn't fly in it) and then skin with aluminum or graphite with an aircraft epoxy as kwales mentions.
My opinion is that the foam probably won't provide you with much given all the welding you are going to do and how you are using the metal chunks (tho' I admit I have a hard time envisioning exactly what you intend to do). Weld the additional layers and fill the actual long with foam idea.gif Then you have a significant cavity filled and I could see that might help and it would be less significant if it adhered or not as it is more of a benefit just filling the large cavity.
Overall, I agree that cars filled with foam tend to trap moisture and rust tho'. If you are creative, you could come up with a simple setup and measure the torsional rigidity of the car as is. Weld all the stuff in, remeasure. Then foam and remeasure. Post results here smile.gif
Jeff Hail
Something that needs to be brought up. If a chassis is altered and made to be too stiff and rigid it will tear itself apart. If you take a 914 and make the center section so stiff and rigid the rear (behind the firewall) and from the (cowl forward at the lower longs and hinge pillar's) become the soft flexible weak links. A chassis as a whole needs to be made equally rigid across the platform or stress's are transferred to other area's that may eventually fail and most likely will. From an engineering standpoint this would mean extending rigidity,additional stiffening and crossbracing from the center of the chassis to both front and rear suspension control points up to at least the towers. This can be done by truss (aka roll cage with tubes parallel and triangulated uprights from the horizontal plane)
The area from the firewall back (rear longs that go upright to the shock towers are like levers). They are designed to rise and fall with body flex, suspension compression from normal road undulations. They also provide controlled deformation (upward) in a collision. This flex is transmitted into the mid longs or torque box at the firewall junction and rockers. If you look at the 914 design you will see that this is an especially weak area by design.
A simple example of torsion, shear and compression would be one chassis with a full tube structure and one stock. Install 300 lb springs on both which one would fail first? Obviously the stock unaltered tub will. The factory came up with a compromise by installing soft (example 90lb springs) and the stock chassis takes up the rest. By design the chassis will only put up with X amount of flex cycles and the suspension absorbs the remainder. Easier to make soft springs and flexible pivots (suspension) than creating a strong roofless chassis as the 914.
Another area of focus is the rear section (behind the torque box) and also from the (cowl forward). The cowl is about 1/2 as high as the length of the center longs. This is a powerful lever created on the longs if you can see it as a hinge mechanism. The same occurs from just behind the doors from the qtr panels rearward. The factory made the longs thicker, boxed and wide to compensate for the thinner sheetmetal in the fore and aft area's of the unibody. Why? If the gauge of metal were the same across the platform the center section would be overcome by at least 12 times the energy imposed by the areas behind and in front of it. The middle would succumb to metal fatigue and fail.
Taking this further on the 914 unibody. I have never seen a passenger side long crack from fatigue. I have seen numerous driver side longs cracked at the E-Brake notch in the long. The reason for this is the right side long has a long and unobstructed box. It's elastic limits are greater because it is allowed to flex more through its length of travel (span). The drivers side is limited by the E-brake notch. The energy or flex comes to a hault at the notch (underside of the inner long) and the same amount of energy on the opposite side is only allowed to to travel say 1/2 as far.
Everyone knows when you put on a thick tight fitting sweatshirt your arms become harder to articulate if it fits really snug. Imagine the above paragraph with one armed cocooned in a tight sweatshirt sleeve and the other without. You will get the picture.
jamara
QUOTE(kwales @ Nov 15 2007, 05:41 PM) *
Ken
I'm beginning to see the whole picture better given everyone's postings. The more I think about it, you are right about the torsion of the long not being an issue. As it is designed to function, it does not suffer these types of loads because it works in tandem with all the other components. By itself, sure it might torque (twist, warp, whatever) along its lateral axis. Not so much the problem given the unibody construction. duh.
I may need to think of this more holistically. And, the more I do, the more a cage seems like the absolute best solution. headbang.gif, since I don't want one. Anyway, I just have to remember this is for fun so if I'm just reinventing the wheel by making an inferior wheel, then aktion035.gif.
I suppose this leads me to the next question, what exactly is the Engman kit doing? All of my pondering came of considering that design. Some have commented that it ties the longs and firewall together and simply makes the longs thicker and thus stronger. I guess my main idea was that the long could be made even "thicker" (functionally) than the Engman kit by the method suggested. Perhaps this is the wrong sort of "thickness"?... I guess that might be what everyone is getting at.
By the way, I think my little drawing lacked sufficient connecting tubes between the skins to supply the desired effect. I was really shooting for a kind of honeycomb. Plus, too many connecting tubes and suddenly, weight is a problem again. But, as stated, that was also the idea with the foam. Less "honeycomb" tubing is needed when using the foam... maybe... blink.gif
Ultimately, I suppose I should just say that what I had in mind, functionally speaking, is to layer what amounts to 1/4" angle iron onto the outside of the inner long, over the top and down the sides to the floor, then reinforce the lower firewall. It would be an uberEngman kit, only not much more weight for the strength. But, 1. It probably wouldn't work as I'm envisioning. 2. Even if it did, it would be a hell of a lot of work.
Oh, and regarding the foam idea, I'm giving up on it for now. However, I think the issue with the foam and rust is that over time it cracks, becomes overly brittle, the surface bond to the metal breaks, like old paint, seam sealer, or something, and then it lets in water and corrodes stuff since moisture gets trapped and can't evaporate. I don't know as I've never really dealt with it. If things were Por-15ed first, that might help, but who knows over time.
Thanks everybody for the responses. Thanks especially for humoring a newbie who is WAY more of a dreamer than a practical thinker, and just smart enough to be dangerous but not smart enough to be particularly useful. That's at least what my friends tell me... oh, and my boss. av-943.gif
Katmanken
As one guy that did aircraft structures taught me,
" a glue joint is no better than the surface it sticks to"
What he meant was that if you handle a surface barehanded, and apply glue to it, a lot of the glue is sticking to your FINGERPRINTS which are a layer of grease.....
So, best glue ( or foam) joint is bare metal to glue (or foam). Add a layer of paint and apply glue (or foam) on top of it and you are depending on the adhesion and shear strength of the PAINT to the metal. And the paint adhesion and shear strength is a lot less than that of the glue.
As per the foam and rust, it isn't about moisture. It's about corrosiveness of foam over time to the point it eats a hole in the metal. In a 1973 Superbeetle, in the roof, between the rear quarter window and the rear window, is a section of steel. Under the exterior paint and steel is foam. There is no path for moisture to that area. To access it, you have two choices, cut through the outside of the car, or go inside, remove the ceiling liners, and cut through a layer of steel reinforcement to find..... FOAM. Under dry foam, with no access to moisture, I will guarantee you will find agressive rust coming from the inside out. Next to the foam, you will find unrusted metal.
In the teener, its in the trunk lid and near the outside of the tail lights.
Ken
Jeff Hail
QUOTE(jamara @ Nov 16 2007, 02:16 PM) *
Ken
The Engman kit is like "double bagging" groceries. No pun...just an easy way to understand the dynamics. It is a good well designed product for a reasonable price. Considering the benefit of it's purpose and performance it is the best option for the money and weight which is low.
woobn8r
If the "ENGMAN" kit is "double bagging" then is the further addition of the Mayeur kit redundent...or overkill.
S.
JPB
I like the idea of making the car stiffer but it is by far better to keep the car original. The purpose of making the car stiffer depends on application. If the car is gone structuarly then, one has to make a decision on which way one needs to go. This foam stuff is not cheap. Going original is not cheap either when one consideres the price if replacement longs and such. Its probably cheaper still to just get a good tub and use the other car as a donor which proves a point in that it far better to get a complete and drivable car for 4K than get a beater to drop some serious cash into. If you want race car parts, its also good to look for a race car with everything you want in your car since these are usually well maintained as well as being good tubs.
If I were to start over again, and I will, I would make a cool rolecage that goes at the role bar, ties to the e-belt bolts, runs horisontal to the rear shocks area via the fire wall, welds to a 1/8"X 3"X4" angle iron sill on top of the longs, run another pipe over that sill about 6" above it tied with stub pipe under it on an angel, at the front of the front door weldes to that 1/8" angel with another vertical stub then runs on to tie to the front wheel wells. I'd put a cross bar at the rear role bar frame and probably another at the dash to tie the two extensions going to the front wheel wells. This will stiffen it up and keep the role bar low and away from site when driving. I would also tie the two front and rear shock towers with cross bars. At the sill tube and the rear role bar, there would be another tube going at an angel next to the seat but not in the way when one enters the car. beerchug.gif
