JBart
Nov 14 2007, 11:08 PM
Looking for some help installing the Crane xr700 into a 019 dizzy . Does anybody have pics. of one installed looking in the dizzy so I can see which brackets and shutter to use ? The directions suck or I can't read . ( It might be me)
Thanks,
jbart
Van914
Nov 15 2007, 04:21 AM
The shutter is easy do you have a 4 or a 6? Two brackets are used. The trick is to get the sensor positioned under the cap. Not too hard. I used the small bracket on the dist plate and the long slider on the sensor. The shutter has to be installed with the sensor at the same time.
Mine worked like a charm for 8 years, until I went to a 3.0 six.
Van
blitZ
Nov 15 2007, 06:27 AM
I also have the Crane, which works great, but setup is a bit tedious. It's easier if you pull the distributor. Once you get the bracket on leave the slider loose, you'll need to be able to move it during the final configuration. IIRC, I had a hard time getting the wheel on the shaft and had to trim a little material out of the inner corners.
Van914
Nov 15 2007, 07:27 AM
To get the wheel omn the shaft I used the rotor to push it on.
van914
