QUOTE(stateofidleness @ Nov 17 2007, 04:45 PM)
i noted that mine was a 76 in point 1.
and bperry i know i got an "answer" in the other thread, but i get conflicting answers as well. im just double checking and getting everything ready for reassembly.
from what i gather, on my '76, the tank in and out are 7mm, the tunnel lines are both 5/16"(is that the same as 7mm?) and the fuel filter on mine is a dark gray plastic square box too (are they the same mm on both sides?)
what does the 7x13mm hose look like? and is it available locally?
7x13 is black, smooth (not braided), kinda stiff rubber, with cords molded into it. 7x13 refers to the inside diamater- 7mm- and the outside diameter- 13mm. The original fuel hose had 12mm OD, and those clamps will not work well on the 7x13. Some use 7.5 x 13, and rely on the clamp to secure it. I got a piece of 7x13 at the Porsche dealer once, but I generally go internet order these days. I've gotten it from Bus-Boys.com (copied below)-
Hose - Fuel High Pressure
Genuine Continental 7mm High Pressure Fuel Hose with smooth covering, no outside braided cloth. Our opinion is that this a much better hose than the original braided hoses you find on the some of the FI Buses. Sold by the foot, not the meter like some other places. 12 to 15 feet usually does the engine compartment, supply lines and return lines, depending on the year.
N 20281.12 1974-1979 $4.10 per foot
(Note: We do carry the cloth braided variety for the fanatics - order N 20357.12 $2.00 per foot.)
Van-again also has it, with the clamps in a set at
http://www.vanagain.com/search_result.asp?...llAction=Page+2------------------------------------------------------------------
Divide mm by 25.4 to get inches. So 5/16" is very close to 8mm (7.93 actually).
7mm is .2755".
My '76 filter has a bigger nipple on the outlet, which goes to the pump. I don't remember the size off hand.
