I have a 2056cc that has to be setup and broken in. It has a cam with 462 lift and 270 duration, 2.0L crank, rods, and heads, CDI box, Weber IDF 40’s, stock headers, and Bursch exhaust.
My question is, what is a good basic setup for the Weber’s? Venturi's, main jets, air correction jets, emulation tubes, idle jets, etc.
I have a set of the tall and short intake manifolds. I was going to go with the taller set unless there is a reason not to. Also I have a set of the taller velocity stacks that I was going to use.
And which spark plugs would be good? Could I use Bosch W8CC and gap them to 0.040”?
The car is for autocross use only.
