QUOTE(craig downs @ Nov 16 2007, 11:53 PM)
If you allow your engine a couple of minutes to warm up then you shouldn't
blow any filters. With the ball not allowed to open would create a full flow condition
but the stock arrangement is restrictive with its small galleys and many turns
since i'm not re-routing the oil to full flow, i have what i have as far as the stock internal oil passages. do you think this would be more restictive to "jb weld" over the relief than to let the oil bypass the filter normally? i guess with my high volume pump, running a good mahle filter and with warming up the oil i should have no oil starvation problems with
better filtation. i would also want to make sure the filter is changed religiously so the oil does not block/starve as i have no bypass... too bad there isnt an adjustable spring/pressure setting on the bypass
by the way when full flow is added which rear passage is elboed? (not at the oil pump) is it one that is behind the flywheel, only acessable with motor out? my passages are drilled & tapped and wonder if it can be done at later date when installed
