Tired of running around hitting every auto parts store in the area just to find that that either they don't know what a helicoil is, or that they don't stock the one I need.
I stripped an exhaust stud removing my heat exchangers, and it turns out that the PO had helicoiled it once with an 8mm one. Luckily for my it looks like the coil itself failed, rather than the threads being stripped as the heliciol literally broke apart in pieces. I was able to get the pieces out fine, and now I have a replacement helicoil but cannot find the tool to save my life. I am trying to avoid buying the kit since I am only doing 1 stud, plus if the helicoil doesn't end up working I am going to just retap the threads to 10mm and be done with it.
Bottom line is I don't want to spend the $ on the kit when 1) I only need it for one stud and I already have the correct coil, and 2) I may end up not using it if the threads are indeed shot.
So, all I need is the actual tool that installs the Helicoil. Anyone local have one on hand they could loan me? If not local, I'd happily pay postage and throw in a few bucks for your trouble as it would still be cheaper than buying the $40+ kit, plus I need to save for a torque wrench too :-) Please PM me if you can help.
And on a side note, all the auto parts stores in my area suck. They're great if I want to buy a license plate frame or some cheap seat covers, but beyond that they are sorely lacking.
