BMXerror
Nov 18 2007, 05:51 PM
Okay, first question is simple and on topic. Does anybody know what tap size to use for the VDO oil temp sender?
Second question: I know there are a lot of engineers on this website and some who are familiar with Solidworks. Where did you get your copies? Did you go strait to Solidworks, or through a dealer? What options did you get and how much did you pay? I'm a manufacturing student and am just getting into CAD, but I have some big ideas that I'd like to start laying out in Solidworks, or maybe Inventor (you Inventor guys feel free to chime in too)
Thanks.
Mark D.
Dave_Darling
Nov 18 2007, 07:02 PM
Use whatever size the threads are on your sender--there are many sizes available.
I think the stock one is M14, but I forget the pitch.
--DD
904svo
Nov 18 2007, 08:25 PM
Oil tempture sending unit is 10mm x 1, a 1/4-28 NPT will also fit the hole but
don't over tighting it, it will crack the case!
type47
Nov 19 2007, 08:04 AM
i've always thought the VDO sender that screws into the oil drain plug location was the way to go for a car that never had oil temp gauge. the sender is a bit exposed but it's a screw in application instead of a drill and tap process. that said, i have the taco plate sender in both of my 914's.
Cap'n Krusty
Nov 19 2007, 09:32 AM
QUOTE(904svo @ Nov 18 2007, 06:25 PM)
No, it's not. The oil PRESSURE sender is 10 mm x 1.00, which is very close to 1/8" NPT. I've yet to see one overtightened enough to crack the case, but I'll be the first to admit I haven't met every hack in the world .................. They seem to come right out of the walls when you least expect it. The Cap'n
BMXerror
Nov 19 2007, 12:09 PM
Okay, nevermind. I just discovered how many sensors that VDO makes. I did find a place to crosscheck part numbers, though, so I can figure out what it is.
Anyone gonna take a stab at the Solidworks question?
Mark D.
Foster
Nov 19 2007, 07:11 PM
While I haven't checked into it lately, I do know that Solidworks likes to get copies of their software into as many hands as possible, and have a lot looser licsencing issues than some other packages (ie Autocad).
You may want to check with your school to see if they have some inside deals. Otherwise, I just did a Google on solidworks and came up with sites offering a "student" copy for $90ish. I'm not sure what the difference between that and a full blown version is, but if your just learning I'd be willing to bet that it'll fit the bill just nicely.
Joe Ricard
Nov 19 2007, 07:18 PM
The Capt has me crakin up tonight.
Dude that shit is funny.
Ya know you could design a billet plate in solid works to go in place of the taco plate blank cover.
Zimms
Nov 19 2007, 07:44 PM
QUOTE(Foster @ Nov 19 2007, 08:11 PM)
We had it at a company I previously worked for, and at the time employees were allowed to load it on their personal machines. The Solidwork rep stated that it the seats were paid for, and they wanted to encourage people to use it as much as possible. This was in 2000.
BMXerror
Nov 19 2007, 08:47 PM
I have a free, licensed student version right now (only a 90 day license), but it doesn't have assemblies. That's "kind of" important. Right now I need solid models, sheet metal, and assemblies, but eventually I'll want the finite element analysis. I kinda doubt that's in the student version, but I'll look at it just the same. Thanks guys.
Mark D.
BTW, I have the M14 X 1.5 temp sensor. It will be going in soon.
davep
Nov 19 2007, 09:37 PM
On the SolidWorks, a new version is limited to one instance only; if you want to use it on another machine you have to transfer the instance via the web I think. In any event it is one license one physical machine. Only available on Win XP and up, and the machine spec is significant.
Check with a dealer for a license but be aware that the maintenance agreement is costly as well, and that is where you get your support and upgrades. Check out the SolidWorks website for student editions, they are cheap but limited.
BMXerror
Nov 19 2007, 09:49 PM
Well, I'm very limited as well. It'll probably be another 5 years (bare minimum) before I have my engineering degree and know how to use all that that program offers. One machine is fine. It'll just be on my home computer. It's a gaming hotrod, so it's got plenty of capacity. Thanks for the insight. Gotta go to bed.
Mark D.
chris914
Nov 19 2007, 11:48 PM
Check your school’s bookstore for a student version.
Check to see if your school has a site license.
Bittorrent
Aaron Cox
Nov 20 2007, 11:13 AM
QUOTE(chris914 @ Nov 19 2007, 09:48 PM)
Bittorrent
i think ours are 1 yr licenses... around 100 bucks for a student/educational copy
chris914
Nov 20 2007, 09:18 PM
euro911
Nov 20 2007, 09:53 PM
Solidworks is great for any design work, including chassis development.
SW design and a finished product (top tree on one of me scooters). SW produces G codes for the mill
I'd think you could get a special student rate through your college administration ... ask your instructor
type11969
Nov 21 2007, 10:52 AM
Usually a liscense of SW allows you to install it on two machines, one at work and one at home. Get a job somewhere using SW part time and you've got a copy. COSMOS, the SW FEA software, is pretty pricey at over 10k for the pro liscense (same deal, one at home, one at work) and the maintenance fee each year is something like 20% (don't need to buy the maintenance contract though). COSMOS is crappy though, get Ansys for another 6k, it is well worth it.
SW should be very easy to "find", potentially Cosmos as well. Google released a cad package as well, never used it and I am sure it pales in comparison to SW, but the basic version is free and the pro version (which seems to include the ability to create drawings) looks to be not too expensive. Might be worth checking out.
-Chris
BMXerror
Nov 21 2007, 11:47 AM
QUOTE(type11969 @ Nov 21 2007, 08:52 AM)
-Chris
Good info! I am trying to get a job at an experimental shop where I believe SW is used, so that might be an option. However, I am BY NO MEANS and engineer.... yet. So I probably wouldn't be able to tell the difference between Cosmos and Ansys. BTW, has anyone had any experience with Cosmos Floworks?
Mark D.
