914-8 and the Cap'n are most certainly correct. (And they know it)
You need to re-jet your carbs.
Apparently you are running lean without the shop towels.
The reason it runs better with the shop towels is that now the engine is seeing LESS AIR and the same amount of fuel as before the towel trickery.
The engine now "Sees" a more correct air / fuel mixture.
That is what is telling us your engine is running LEAN and needs to be re-jetted.
Ya see... We have all been here before.
The above diagnosis assumes your timing is correct. Your valves are set correctly, if you have points the dwell is spot on. AND your Carb linkage is set up properly.
Plus the correct fuel pressure, your carb floats are set right.
You have NO intake leaks...!!!!!
After ALL of this is deemed correct.
THEN you re-jet the carbs to make your engine run correctly.
Think of it as a combination of things. If ANY of the above are not setup properly. You will forever be tuning AROUND the flaw. And achieving a tune of mediocrity. (At best) And that is if you are lucky...!!!!!
If you simply want to learn more about your carbs and tuning.
You might want to contact either of the following:
Mike Harney
He is truly one of the great Carb gurus in the air cooled arena.
Contact Name: Mark Harney
Telephone
Shop: 615-371-4228
Cell: 615-587-1000
Shipping Address
Harney's Carburetor Clinic
9426 Highwood Hill Rd
Brentwood, TN 37027
Or Contact Art Thraen at ACE. He is another amazing fella that re-builds and jets out carbs as very few can. He is so good, peeps send him carbs for VW and TYPE IV engines from all over the world.
Art Thraen
360 W. 6100 So.
SLC, UT. 84107
Mon-Sat 9-6
Phone: 801-747-3340
Fax: 801-747-3341
Website:
http://www.aircooledengineering.comHope some of the above makes sense. if not.. PM me fpr a phone number and I will walk ya through the basics and WHY you should do what we are suggesting.
Cheers,
Clayton
