Beamer13
Nov 19 2007, 04:16 PM
Here is a pic of my ECU from my car. '74 2.0 none of the ones I am seeing looks even remotely close to this??? As you can see, it is almost square and thin, shaped almost like a radio??
Cap'n Krusty
Nov 19 2007, 04:19 PM
It's an L-jet ECU. 74 only, 1.8 only. I may have one, but it may take a few days to locate it. I may also have the harness, and maybe even the double relay. The Cap'n
Beamer13
Nov 19 2007, 04:21 PM
QUOTE(Cap'n Krusty @ Nov 19 2007, 04:19 PM)
Awesome!!! I was actually told that this was a 2.0 ??? How can I tell that?? You'll have to forgive me as I am a complete Porsche and 914 novice
SLITS
Nov 19 2007, 04:31 PM
The aluminum mount tabs and rubber/plastic covering.
Beamer13
Nov 19 2007, 04:34 PM
So I am to assume that the plastic cover must've melted off?? There is no plastic anything on this with the exception of the plug that went into it? Is there some sort of number somewhere to verify or perhaps some other telltale sign that this is not a 2.0 as I was told it was??
TheCabinetmaker
Nov 19 2007, 04:58 PM
1.7,1.8=4 intake studs and plugs on top of head
2.0=3 intake studs and plugs on side of head
There is also an engine code stamped on top of the case.
Cap'n Krusty
Nov 19 2007, 04:59 PM
It could still be a 2 litre engine from a bus. First, find the engine number on top of the case. Second, look at the attaching bolts at the end of the intake runners. 1.7/1.8/2.0 Bus use 4 bolts, 2.0 914s use 3, and the spark plug holes are on either side of the manifold flange. Yours are on the top, so it's one of the former, not the latter. You've been misled. The Cap'n.
orthobiz
Nov 19 2007, 05:00 PM
1.8 v. 2.0:
If the end of the tubular spout on the air cleaner is parallel to the back margin of the rear trunk when you are looking in the engine compartment, you have a 2.0.
If it diverges (points slightly toward the passenger seat), you have a 1.8.
While you don't show a lot of the air cleaner in your pic, it looks to be a 1.8. Plus the air cleaner is a bit more to the driver's side in the 1.8, more central in the 2.0.
Paul
Beamer13
Nov 19 2007, 05:08 PM
Here's a couple more pics. I hate it when I don't know what I have
Beamer13
Nov 19 2007, 05:09 PM
TheCabinetmaker
Nov 19 2007, 05:41 PM
like the C'apn said, 1.8!!!!!!
type47
Nov 19 2007, 05:43 PM
looks like a 1.8 L-jet. the air cleaner on a 2.0 D-jet covers more of the top of the motor with a big air cleaner; an L-jet covers more of the drivers side/half of the motor
SLITS
Nov 19 2007, 05:58 PM
Oil Filler is 1.8 L-Jet / Plenum is L-Jet / Air Flow Sensor is L-Jet
ECU .... 11/73 - 07/75 .... 1.8L ... Bosch 0 280 000 103 or if rebuilt CU66X
ECU .... 08/72 - 12/75 .... 2.0L ... Bosch 0 280 000 043 or CU14X
08/74 - up ... Service Replacement ... Bosch 0 280 000 052 or CU16X
Beamer13
Nov 19 2007, 06:15 PM
Ok, so which side of the engine do I find the engine number???
Beamer13
Nov 19 2007, 06:20 PM
You are all awesome!!! Thank you for your help. Cap'n, I'll get that engine number for you, if I can find it. I will bring my laptop with me so that I can stay connected to try and get some answers.
Thanks Again!!!
SLITS
Nov 19 2007, 06:42 PM
The number should begin with EC or AN if it is a 914 case ...
Will be found stamped into passenger side angled flat rib near transmission (rear of case) on top of case .... passenger side.
Beamer13
Nov 19 2007, 08:04 PM
Alright, here it is! It is a Porsche engine whew!!!!
The number is as follows: EC007174, so it is a 1.8... I just talked to the PO and he was just as surprised as i was!!
bmtrnavsky
Nov 19 2007, 08:32 PM
QUOTE(Beamer13 @ Nov 19 2007, 06:04 PM)
Could be a 1.8 with a big bore kit...
Beamer13
Nov 19 2007, 08:35 PM
This is true, guess I'll find out when I get the engine out and start replacin stuff. Right now I'm just happy to know what I'm dealing with, and what I'm looking for
I like the car for what it is, and just want to know that I'll be able to take it on the road come Spring :-)
GaroldShaffer
Nov 20 2007, 05:55 AM
I have a complete spare 1.8 engine my garage. I beleive my engine for the race car is 1.8 with a big bore kit. Anyway if you need any FI parts, CPU, harness, ... let me know. I was going to post then egine for sale here, but since I have the race car now, you got to have spares.
type47
Nov 20 2007, 08:16 AM
QUOTE(SLITS @ Nov 19 2007, 02:31 PM)
here is a pic from an ebay ad (no affiliation to ebay seller) of the ECU and the black plastic cover. the ECU mounts to the battery tray and to the engine shelf
Beamer13
Nov 20 2007, 08:21 AM
QUOTE(Garold Shaffer @ Nov 20 2007, 05:55 AM)
Actually, I do need the CPU and the harness for the 1.8. Is the one you have the L-Jet?? How was your trip back this weekend?? It was really nice meeting you!! I can't wait to get this baby done!!!!
