QUOTE(stateofidleness @ Nov 21 2007, 03:41 PM)
do i have to have the car on stands to JUST remove the old lines? ive got some free time today but no replacement lines yet.
do you pull the old lines out from the back or the front tank area?
and im guessing theres somethin that needs to be disconnected in the engine area to facilitate the lines being able to be pulled through?
I would put it on stands but I guess it, depends on how skinny you are.
You will have to be under the car to do this.
Crawl under the car and have a look. It will be fairly obvious what needs
to be disconnected. Shouldn't be much. A few clamps and possibly a few holders.
Watch out for leftover fuel in the lines as there will definitely be some.
Don't forget about the 2 sets of clips in the center tunnel (at least there were 2 in a 74).
These hold the lines inside the tunnel.
One under the plate that is under the center tray where the wiring harness comes
in and the other under the shifter. The shifter will have to be removed to get to it.
The lines will get hung up on these if you don't loosen them. You will also want
to use them to secure the new lines.
--- bill
