tango-52
Nov 20 2007, 04:41 PM
I put a pair of these in my '73 using the adapter brackets because I didn't want to cut on the floor. The seat itself has four fiberglass feet that extend down about an inch and the mounting bolts are long. Can I grind off the feet and use shorter bolts? Any suggestions are appreciated.
jasons
Nov 20 2007, 10:21 PM
A lot of seats don't fit in the 914. Most people using a seat like that use the Corbeau Forza. It fits, but its not as nice as the seat you have. You should ask Corbeau about grinding the feet. You may have no choice but to floor mount those.
tango-52
Nov 21 2007, 01:33 PM
I just got off the phone with Corbeau and was told I could grind off the feet, and if I need to I can even just drill new holes through the bottom as long as I reinforce the holes with large diameter bumper washers. Sounds like I have a project for Friday. I'll let you know how it works out.
blitZ
Nov 21 2007, 03:44 PM
Please post some pictures when you get them installed. Are you retaining the backpad?
tango-52
Nov 21 2007, 09:32 PM
I will take pictures and I intend on retaining the stock backpad.
jonferns
Nov 21 2007, 09:38 PM
tango-52
Nov 23 2007, 10:03 PM
It's done! And it worked out real well. Now I have to put all the pictures in a useable format.
