QUOTE(vesnyder @ Nov 23 2007, 11:54 AM)
I am assembling my first motor and have several questions. When I rotate after putting the valve train together the distributor pops out? I've already lost my distributor alignment, but why would this be happening? Any easy way to realign the distributor? Maybe I was rotating the motor the wrong way - what way should I rotate the fan? Thought it was clockwise?
Thanks!
this should not happen if you have the clamp tightened. if it's just in the hole
when you spin it, it may have a tendency to pop out of the groove.
even if the clamp is tight, but not totally clamped, it can pop out when your driving.
I learned that about 15 years ago
to align, put the engine at TDC and place the score-mark on the distributor rim
where the rotor is pointed. this will get you into the ballpark and you should be
able to start the engine. time it appropriately from there.
good luck.
