Whew! back in the country, finally, and ready to get my car running again... real glad i wasn't flying from london. quick question:
the 914-4 dizzy SHOULD only go in its [relatively] correct orientation, right? -- i.e. one should NOT be able to put it in 180 degrees backwards (unless the vacuum unit is obviously in the wrong place)? this makes sense to me because the rotor will only go on one way, but i just want to confirm this...
then, i should be able to line up TDC (approximately) by turning the engine to where the rotor points over the little hash mark on the dizzy. my TDC mark ain't there. and i'm trying to avoid pulling a valve cover. just trying to get the thing started so i can time it.
happy new year!
nathan
