QUOTE(ejm @ Dec 2 2007, 07:33 PM)
Can't see it in your pic's but I'm pretty sure there are two vacuum fittings on it, correct? It is a thermostat for intake air pre-heating. The air filter housing would have a vacuum operated flap for intake air that switches between air heated off the engine or non heated air. Was used on busses and type 4's.
No, that's not it. The part you're referring to is is in the piece on the left side of my pic & does just what you say.
This part, though it seems to be thermo affected, is NOT attached (at least on my 914) to anything. Has two tits that hang below the cleaner, but not connected to anything. Am I missing a vac hose or two here?
Pat
