turtleturtle
Dec 3 2007, 12:52 PM
Have a question, can you take out the blower without having to drop the engine? I need to see if the flang is messed up do to my crank shaft pully coming loose. I have not been able to take a look at it.
type47
Dec 3 2007, 01:19 PM
don't forget to tell us the year and engine size of your car.
sounds like you have an early 1.7 car, if so, the heater blower fan is mounted on the top of the engine fan housing by some bolts. should be able to unbolt...
turtleturtle
Dec 3 2007, 01:52 PM
QUOTE(type47 @ Dec 3 2007, 01:19 PM)
Sorry about that, I have a 72 with the 2.0
TheCabinetmaker
Dec 3 2007, 03:07 PM
I think he's talking about the impeller fan, not heater fan.
Turtle, you can see the fins thru the timing hole, or use a mirror to see the front of the fan.
turtleturtle
Dec 6 2007, 02:48 PM
QUOTE(vsg914 @ Dec 3 2007, 03:07 PM)
Yeah, but can you take out the impeller fan on a 2.0 without dropping the engine??
Cap'n Krusty
Dec 6 2007, 02:52 PM
Yes. You need to remove the front tin (2 pieces). Comes out the bottom. From there, it's a piece o'cake.
The Cap'n
turtleturtle
Dec 6 2007, 02:54 PM
QUOTE(Cap'n Krusty @ Dec 6 2007, 02:52 PM)
The Cap'n
Thanks!!
turtleturtle
Dec 6 2007, 04:07 PM
I took out the blower and figured it out, thanks to all that helped out. The bolt that holds the blower to the crank shaft came loose somehow. The key is missing also, so on to fixing it tomorrow when I get my new key.
Oh, and you don't need to take off any of the fan shoud to get the blower off, at least I didn't. I just took off the fan guard, the fan center bolt, and the belt and it was off.
TheCabinetmaker
Dec 6 2007, 04:14 PM
SteveL
Dec 6 2007, 07:10 PM
C'MON -
Somebody who still has the picture, post a reply referring to the "Leaf Blower"
turtleturtle
Dec 9 2007, 06:25 PM
Got it all back together and it is running great!
