QUOTE(slim72914 @ Dec 7 2007, 08:15 PM)
The driver you linked to will work. Although it isn't a really efficient driver at 82db at 1 watt, 1 meter. But thats Ok for this scenario.
The VAS is about a 1/3 of a cubic foot. NOT including driver space of 0.019 CF.
So you would need a sealed enclosure of about 65 - 75 cubic inches of space if ya wanted the driver to go reasonably low. Bout 43hz at a 3db down point.
Thats an internal dimension sans the thickness of the enclosure itself.
The smaller you make the enclosure. The HIGHER the base starts. (In Hz)
The bigger you can make the enclosure. (Within the parameters of the driver)
The LOWER the driver will go. This holds true for all enclosures to a degree.
If you run a properly ported enclosure in the same sized "BOX" as a sealed enclosure. The ported driver will go lower. Then when it hits it's physical and electrical threshold of efficiency. The ported driver will distort before the sealed enclosure will. (With rare exception)
And ya got no room for a real ported enclosure anywhere except the center console area. Also ports WITHIN the enclosure take up room ya need for the proper sizing of the driver. if ya had anything other than a teener or FIAT X/19.
This would be a cake walk. I see two different scenarios that work. Either use the center console like Morphin Spectre sells here on the this site. OR the Salad bowl method. Unless ya want to cut up the car even more than the salad bowl setup....
Ya might want to call up JL audio AFTER you figure out how to build the biggest enclosure you can and still fit within the parameters of your cosmetics and mechanics. They will then tell you what works. As JL makes at least another 100 different speakers that aren't listed on their web site.
Start with a KNOWN enclosure size (Internal enclosure dimension measured in cubic inches).. THEN ORDER THE DRIVER...!!!!!!!!
In that way you will achieve a better result. period....
Ya know why..??????
Would you ever order a cam before you knew how much your heads flowed...?????
NOPE... Cause you will always order the wrong cam. Period end of story.
At best. you would achieve mediocrity. And excellence cost NO MORE MONEY. Just cost ya some time and learning curve. dats all folks...
With the amp you listed. I would order the 4 ohm version of that driver.
Part# 6W04
I would NOT run the sub woofer section of the amp in bridged mode if you like to crank it up. But you can try it. The bridged mode will get you about 3db more speaker output if the amp doesn't cut out. (that doesn't hurt the amp by the way) If it cuts out... Just move the bridge switch to the unbridged mode... SIMPLE.
And I hope your head unit has a separate sub woofer control. Cause it is MUCH easier to tweak your head unit than getting out of the car and turning the sub woofer section of your amp up and down to feed your need for more or less sub base.
Your Base / Treble controls were NEVER made to accurately adjust a subwoofer. That just fucks up your symmetry and sound stage if you do it that way.
By da way. What head unit ya gunna run with this setup...??????
Then again.. I don't know much about this stuff....
Clayton
