hwgunner
Dec 9 2007, 02:57 PM
I have a bunch of items that i can not identify. Can you help??
Pic #1, #2 and #3 were in the same big bag.
Pic #1
hwgunner
Dec 9 2007, 02:58 PM
Pic #2
hwgunner
Dec 9 2007, 02:59 PM
#3
hwgunner
Dec 9 2007, 03:00 PM
Next item is Pic #4
dflesburg
Uh, parts that George sold you in the scoops bags that dont go on 914's ?
hwgunner
Dec 9 2007, 03:01 PM
#5
hwgunner
#6
hwgunner
Dec 9 2007, 03:02 PM
#7
hwgunner
Dec 9 2007, 03:03 PM
#8
hwgunner
#9
hwgunner
Dec 9 2007, 03:04 PM
#10
hwgunner
Dec 9 2007, 03:05 PM
#11
KaptKaos
Dec 9 2007, 03:12 PM
What is "none of these things has ever been in my kitchen?"
TimT
Dec 9 2007, 04:10 PM
some of them are 915 shifter parts
elmonte
Dec 9 2007, 05:05 PM
It looks like #11 is a drain tube for the stock air cleaner on a 6. Hooks to the cleaner with a hose and is bolted to the bell housing
smontanaro
Dec 9 2007, 05:12 PM
#6-#10 look suspiciously like bits of /6 shift linkage (I worked on mine last summer). However I am *not* going to confirm that by crawling around under my car in its unheated garage.
Skip Montanaro
degreeoff
Dec 9 2007, 06:06 PM
1,2,3 look like parts of a release mechanism either front/rear trunk maybe??
jd74914
Dec 9 2007, 06:11 PM
I'm thinking 1-2-3 are shifter related (915).
mskala
Dec 9 2007, 06:27 PM
QUOTE(smontanaro @ Dec 9 2007, 06:12 PM)
Skip Montanaro
Dave_Darling
Dec 9 2007, 09:20 PM
Parts in pic #1 are from a 915 shifter--the part that the gear shift lever goes through. The parts in #2 and #3 look to be from the same place--they would go under the metal ring-thing.
#6 looks like the guide for the rear shift rod on the 914-6 transmission, possibly on the -4 tailshifter? Might also be used in some 911 applications.
#8 goes inside the center tunnel on a tail-shift 914 or a 911. A bushing goes in there and the front shift rod goes through it, just aft of where the gear shift lever attaches.
#9 appears to be the part on the aft end of the rear shift rod of a 914-6 linkage.
#10 looks to be another linkage part, but again not sure if it's 914-6, or 911, or 914-4 tailshifter.
--DD
914Sixer
Dec 10 2007, 04:42 PM
#4 looks like 914-6 Rev Limiter on Relay Board
#5 Tach ballast restior on 914-6 Relay Board
#6 914-6 Shift part
#7 shift blocks for 914-6 that go with #10
#8 Shift rod holder at rear of floor shifter, 911,912,914,914-6
#9 shift fork at tailshifter 914-6
#10 shift rod connector 914-6 at firewall to tunnel rod
