nebreitling
Jan 3 2004, 01:18 PM
real quick, gents
i'm trying to remove the parking brake lever. i was able to get the clip off the pin which connects the cable to the lever, but i can't get the pin out to disconnect the cable. any tips? sorry, don't have a camera
Eddie Williams
Jan 3 2004, 01:19 PM
Mine was rusted together, no solution.
nebreitling
Jan 3 2004, 01:23 PM
that sucks. mine's hardly rusted, but it seems damn frozen. is it "supposed" to be pulled out w/ a pair of pliers or something?
tod914
Jan 3 2004, 01:38 PM
Maybe loosen the brake cables under the car first. It might relieve some tension thats on it. Adjustments are by the blower motors just foward of the rear wheel.
boxstr
Jan 3 2004, 02:13 PM
Remove the cable from this end.
Steve
Jan 3 2004, 02:29 PM
I used WD 40 and let it sit for awhile.
I then used hammers pliers etc.. to get the pin to loosen up, so I could pull it out.
urbanskater
Jan 3 2004, 07:03 PM
a hammer and a phillips screwdriver with a head small enough, or any pin pusher. Give it a few wacks, should pop out.
nebreitling
Jan 3 2004, 07:36 PM
got it. thanks guys
