QUOTE(thesey914 @ Dec 10 2007, 06:15 PM)
When the Ign is switched on the brake light flashes as it should (parking brake switch not yet connected). When the the parking brake wire is grounded the light doesn't stop flashing.
The parking brake switch is grounded when you pull on the brake lever. It is open when the handle is lowered into its resting position.
If you do not connect the wire or the switch isn't installed, the parking brake wire is open thus will not cause the flasher to flash.
If the brake light is always flashing, either the wire to the parking brake switch is touching the frame or the switch on the master cylinder has tripped. You can unplug (just for this test) the master cylinder switch to see if the brake light goes out.
If either of the master cylinder or parking brake switches is closed, the parking light will come on.
Not sure what you mean that the brake light flashes when the flashers are on. Is the brake light on only on occasions or on all the time?
Spoke
