highways
Dec 11 2007, 11:09 PM
So my fuel pump just quit after I plugged in my air heat exchange blower. Did I kill my voltage regulator or something? I tried swapping out the fuel pump relay. No luck. Any ideas?
JeffBowlsby
Dec 11 2007, 11:22 PM
Check your fuses...especially the 25A fuse on the regulator plate.
highways
Dec 12 2007, 12:25 AM
Problem solved. I must have either bumped the 25amp fuse or the fuel pump relay when I was installing the fan. Thanks.
