QUOTE(Scott Schroeder @ Dec 14 2007, 12:07 PM)
I need longer rear wheel studs - can they be removed with the hubs still in the car? There was a recent article in Excellence where they simply removed the caliper and rotor and pounded them out, then used a steel (open topped) lug nut with a spacer to pull the new stud in to the hub..... but that was on a 911.
Any help is greatly appreciated!
yepp, works like a charm. i did the 100mm studs on my car that way. the front is easy, on the rear, you have to rotate the hub just right, there's only one spot where the long studs will clear the trailing arm. it's not a straight shot, but they will slide in. i put some locktite around the beveled part of the studs and pulled them in with a old steel nut. you'll need a spacer for that as the thread doesn't go all the way down ...
Andy
