In the Murphy's Law book....
If you have an intermittent light miss miss on a v8 and want to look at the plugs, the ONE plug you can't get to because it's directly behind a header tube will be THE one that's bad... Right?
Excuse my rant, but I swear, me and spark plugs lately... Grr.... Another one: So the wife's car needs a tune up. It has a V6 mounted sideways. The front three plugs are piece o' cake. The back three are nearly inaccessible... There isn't enough room between the motor and firewall for me to even get a hand on the plugs.
A friend of mine had a v-twin motorcycle that required dropping the motor part way down to remove the front plug because the frame tube was so close.
I say we should make a new law: Whenever an engineer designs something that requires a major pain in the arse amount of work just to access a simple maintenance item, HE should be required to personally show up and do it for you. You suppose that would make them consider stuff like this? Oy.
Ok, rant over.
