I decided to remove the engine to clean it up a little bit. It has just over 80k miles on it. Any suggestions on things I should do now that are near impossible to do once the engine is in? Some items already on the list are:
Clean up hell hole area
Replace rear brake lines (fronts already done)
Replace clutch / pressure plate
Adjust valves
Chase oil leak dripping on pass heat exchanger.
Replace vacuum and fuel lines.
I don't want this to turn into a major project, just enough to enjoy the winter here in FL. I plan on doing a more thorough restoration when I finish my 71E.
Thanks,
Brian
