this morning, i had to go to a meeting in SF and the car was running fine and all was good.
then, this evening i went to pick up my GF from work and when i started the car, the oil pressure went through the roof.
i have the 0-5 gauge and normally the pressure at idle is about ~2 and under full load close to 5.
now i'm getting 4-5 at idle and the needle hits the stop under load.
i checked on the oil cooler and thermostat, both work fine, supply and return line get hot/warm, so the oil is circulating in the lines.
they engine sounds normal and i don't see any oil squirting out of the block anywhere.
anyone know what could be wrong?
Andy
PS: the motor is a '95 3.6L from a 993 ...
