rfuerst911sc
Dec 18 2007, 06:36 PM
I have a 75 chassis that I will be installing a 911 3.0. I haven't looked at the wiring harness yet and I'm not familiar with 914s like I am with 911s so bear with the stupid questions
Did the 75 come with a Bosch CD box as standard equipment? And was it a 3 pin or 6 pin? And of the main players in aftermarket ( MSD , Mallory , Crane ) which is preferred? And why? Thanks guys
echocanyons
Dec 18 2007, 07:12 PM
No the 75's had standard coil ingnition with no CDI
can't answer the second part though
J P Stein
Dec 18 2007, 07:43 PM
If you're going with carbs, I highly recommend one of the multi-spark jobbies & a high voltage coil. Run .045-.050 gap on the plugs and they will not foul.
I use the MSD 6AL & high vibration coil and have had no problems....but I figure they are about all the same. Summit Racing has the best prices I've found.....with great service to boot.
BKLA
Dec 18 2007, 07:45 PM
QUOTE(J P Stein @ Dec 18 2007, 05:43 PM)
JP -
where do you have your ignition mounted in your car? Reasoning behind location selection? Pics?
Mike D.
Dec 18 2007, 07:55 PM
I am also using the MSD 6AL and MSD coil. The nice thing about the 3.0 dist. is that it has a magnetic pick up and, with a slight mod, you can plug it into the MSD box.
effutuo101
Dec 18 2007, 09:53 PM
can you break down the wiring for me?
from the 914/4 wire harness
black/purple tach? ( where did you connect it at)
black ( key power on +)
white (what is this for)
green ( oil pressure stupid light plugged in)
on my 6AL I have to sort out what goes where:
red/orange to + on coil
black in same sleve to - on coil
Large black Batt. Ground
Large Red Batt. +
white wire to distributor ( should I splice in the black and purple?
I found this pic from Aaron, but wanted to be sure before plugging everything in.
sixnotfour
Dec 19 2007, 12:58 AM
auxilliary air valve, (not needed)
No:
MSD white wire goes to your Distributors spade terminal.
BLK/purple goes to tach output on MSD like Aarons dwg.
The wires you labeled from the alternator go like this picture;
sixnotfour
Dec 19 2007, 01:31 AM
Sorry for the slight highjack.
wiring diagrams;
http://www.pelicanparts.com/914/914_electrical_diagrams.htm
DonTraver
Dec 19 2007, 01:36 AM
Couple of things about the tach. A stock 914-6 or 911 tach will not work with a MSD control module. Using the "adapters" won't work either. The tachs need to be modified to run with a MSD. There's a tach place in LA, think it's Hollywood speedo or something like that that can do the mods. A stock 914-4 tach will work with the MSD, but it won't read right, it's set up for 4 cylinders and you can't modify it to work with a 6. I bought a aftermarket tach that fit the hole for about $120, works with the MSD.
Good Luck
DonTraver
Dec 19 2007, 02:18 AM
Looked up the tach I bought. It's a Autometer 233903, 5 inch with shift light. Got it at AJUSA. Still carry it, on sale too. Maybe this address will work. Works on 4,6,8 cylinder engines
http://www.ajusa.com/cgi-bin/stores/detail...p;source=lookupGood Luck
J P Stein
Dec 19 2007, 02:56 PM
QUOTE(BKLA @ Dec 18 2007, 05:45 PM)
JP -
A convenient place where the battery usta' be.... happens to be in a fairly cool spot to boot. Old pic, but it's still there.... or will be when I reinstall it. 5/16" rubber mounts.
effutuo101
Dec 19 2007, 04:47 PM
Sorry for the hijack. Thank you Jeff! I should have spark soon. JP. That picture of your motor is great! When are we going to see it in person?
J P Stein
Dec 19 2007, 05:18 PM
QUOTE(effutuo101 @ Dec 19 2007, 02:47 PM)
That's an old pic.....from when the date goodie on my camera worked.
I dunno. Our first ORPCA AX on 2 March. I'd like to have it running again by then but early March weather is reeeel iffy....we could have rain, snow, ice, or all of the above.....2% chance of sun. I bitched long and hard about the change from 30 March but to no avail.
I'd like to do a couple PNWR's Bremerton events and certainly everything at Packwood come summer.
The site seems to be jacked up,eh?
GeorgeRud
Dec 19 2007, 05:27 PM
Depending how for into the project you are, I would also consider Clewitt Engineering's Electromotive crank fired ignition kit. It gives a great spark, and the timing is much more accurate and consistant than the distributor/points combination.
Depending which unit you choose, EFI is also a possibility down the road. Otherwise you can just control the ignition with it.
Van914
Dec 20 2007, 03:51 AM
When I installed the 3.0 this summer I used the Crane Hy-Fire and mounted it in the trunk. I ran the wires through the plastic cups that hold the top clips. I also had the distributor recurved to work better with the PMO's. One tip I was given is do not cut the green wire that is comming from the distributor. Mine runs great and a very easy conversion.
Van914
