QUOTE(Dr Evil @ Dec 21 2007, 11:23 PM)
A relay is a switch. Your key acts as if it were you throwing the switch. So, you have the power from the battery go directly to the relay (B+), you have the outlet of the relay go directly to what you want to power. Then, you hook up your wire from the switch (switched power) to the relay (it will be obvious most likely) and you are done
When you switch the poser on at the key it energizes the relay causing it to close connecting the circuit to the pump or what ever directly from the battery. Some relays have a separate ground hook up, others have the base as a ground so you need to mount it to the chassis or engine, tranny, etc for continuity.
Clear as mud?
So my next questions are:
How many "Amps can these relays handle? I assume they come in different ratings.
Does one shop for a specific rate relay or can I just go big to play it safe?
Should I get separate relays for separate components or can I get one big relay to switch the pumps together?
Does getting a larger than required relay cause any problems?
I think I remember people putting the relays as close to the components as possible. Is this right?
Thanks. =)
