tagtmeyer914
Dec 26 2007, 07:03 PM
if your fuel pump has a stuck valve for the d port is it possible to cap it off and use the r port and connect the r hose directly back? after all after it has a y connection and the 75 + cars use a 2 port pump. any input?
Cap'n Krusty
Dec 26 2007, 08:27 PM
No. After all, apples are are round, and so are oranges, so why can't you use apples to make orange juice? The Cap'n
Dec 26 2007, 08:53 PM
QUOTE(Cap'n Krusty @ Dec 26 2007, 06:27 PM)
tagtmeyer914
Dec 26 2007, 09:18 PM
it was just a thought considering i have two fuel pumps doing the same thing. i may try wd 4o or gumout first just to see what happens i dont know if i want to try taking it apart. does anybody have a parts diagram of onr of these pumps?
swl
Dec 27 2007, 08:17 AM
If you were going to try something like that, and I'm not saying you should, the way to do would be to remove the valve, seal up passage it was in and then run as a two port.
Disassembling the pump is no biggie. Just the 4 screws you see on the face. The problem is reassembling. There are 2 big o-rings in there that tend to expand like crazy when they come out. You have to dry them off immediately and then leave them for a while a while to retake their shape. If you try to use them again without being back to appropriate size you will probably wind up with a leaking pump.
you will be able to see the valve and the point where it sticks. You will not be able to remove the valve. To do that you have to remove the cap and they don't go back on well.
tagtmeyer914
Dec 29 2007, 05:23 PM
got the fuel pump working. correct fuel pressure and all. f****! i used a battery charger to try and start it there goes the control unit. time for carburators?
